I need wpf drawer tools control on my computer. I am creating datagrids, charts and scheduler controls and I have to have easy access to them for me to create the files correctly. Where can I download the control tools? Are they for free?
Where can I get wpf drawer tools control?
Hello Lynn,
Follow the below steps and links:
1 Click OPC Systems
The above provides a number of options.
2 Choosing Version 4 for .NET Framework 2.0 and 32bit options links:
Varying Products Page
3 OPC WPF HMI.NET equals the link below OPC WPF HMI.NET
(The download link would request you to fill out a form to proceed)
And Yes it is a free 30 days trial pack. A purchase would serve longer.
Hi Lynn,
On this link http://soft.udm4.com/downloading/wpf_graph_drawer/ you will see a lot of drawers that you can look at. These includeÂ
Graph ZX
You can use this to draw all kinds of graphs including line graph, bar graph and pie charts.
EDraw FlowChart Active X control
This is used to draw flowcharts
Advanced Grapher
This is used to create complex curves that require parametric functions.
You can also check this link for other free drawers http://softwaretopic.informer.com/wpf-controls-drawer/
