Hello friends,
Where can I locate application panel setup? There are some instances that we have to configure the settings of our computer applications installed. I need to take a look with these settings to figure out what is missing or needed to be changed. Please share with me a step by step process to locate and configure installed applications. My current Os is Windows 7.
Thanks and Regards,
Mark Lesliez.
Hello Mark Lesliez
Have a nice day. Hope you are fine. You are interested to know that, where can you find the application panel setup? The computer applications which have already been installed are located in 2 places. One is my computer-C drive- Program Files and another is Start-Control Panel-Program Features.
There are 3 types of views in Control Panel. See top right side on your control panel. Click View By option you will get 3 options by drop down menu. Small icons, large icons and category view. First of all from My computer-C drive option you can get your application repair option and you can changed some option from the repair (which software’s are already installed with repair facility).Otherwise from control panel you can select uninstall a program and uninstall the program successfully.
Restart your PC and set up the application again to use your facilities with that application software.
Hope this will help you.
Greaney Mary
