Where can I look for best sound equalizer software?
What is the best place to look for best sound equalizer software and how will I be able to download it for free?
You can find many software for sound equalizer on Softonic website.
They have 5 star ratings beside each software; find one that has more ratings so you can know which one is the best. Because ratings comes from users who already tried the software.
Then hit the green Download button beside each and then run the installation.
Hello Olivia,
If you are interested in having a great quality sound equalizer, I am providing you a link from where you will be able to download around 20 equalizing software coupled with meia players. Have a look.
http://www.blazeaudio.com/products/webeq.html
http://www.freewarefiles.com/RealTime-Equalizer_program_24090.html
Here are several audio equalizers that you might get interested.
Power Sound Editor – one of the many similar audio editing applications that provide everything you need where you can cut, edit, and merge your favorite music. This is best used for adding special effects or sound effects to your sound or music. It supports all early versions of Microsoft Windows including Windows XP, and Windows Vista.
Visit Power Sound Editor. See image.
DFX Audio Enhancer – this is actually a plug-in for Winamp, if you know what Winamp is. It can also be used as plug-in for DivX player to enhance the output of the music on your computer. I’ve been using this plug-in together with Winamp for very long years until now and nothing really beats playing your music with these two applications.
It supports Windows XP, Windows Vista, Windows 7, and Windows 8. Visit DFX Audio Enhancer. See image.
AIMP – the best audio player that is brilliantly designed and offers lots of features that will make you consider it your default audio player. You can manage your MP3 files in a library as well as edit their tags and added support for karaoke files. It offers the usual playback functions available in other audio players including an 18-band equalizer, visualization effects, fade effect between songs, and more.
It supports Windows XP, Windows Vista, Windows 7, and Windows 8. You can also use the player to play online streaming radio stations. Visit Softonic – AIMP. See image.
