Where can I open those educational SWF files? I need your suggestion on the software that has the power to open SWF files. I want to edit some SWF samples and make it as a new instance. I wish those software that you will suggest is compatible with windows 7 starter 32 bit operating system.
Charles Marry.
Where can I open those educational swf files?
Hello!
The easiest way to open SWF files you can use:
Adobe Flash Player.
Internet Explorer: Right click the file, Then click (Open with), Then choose IE.
But if you want to edit your SWF files, I suggest you download “Sothink SWF Quicker”.
Supports importing and editing SWF file.
Supports editing flash.
Enjoy and Have a great day.
Well Marry
There is too many software as flash player 11 can make the solution for you. It can run all kind of SWF files. But in the case of editing them you may use swf decompiler.
A free decompiler can be download from http://www.sothink.com/ or swfdecompiler official site. Both the site can provide you a great software to make extra instance with existing.
Another great software is adobe flash professional CS6.
Thanks
mvirk35
Hi Charles Marry
I suggest you to install SWF & FLV Player to open those files. For your convenience I am entering URL also to download the player.
Regards.
Hi Charles Marry!
Here is some SWF opener tools. You can use Adobe Flash player for open SWF files:
You can open it directly:
IE: Right Click the SWF file > Click Open with > Choose IE to open the SWF file.
This will help you to open SWF files.
janchan
