Where can I possibly get the samsung wave gps code?
Hello experts,
Where can I possibly get the Samsung wave GPS code? When trying to open the GPS of my Samsung wave mobile phone I was wondering all about the code that needed to be entered in the space provided. Can you share with me some answer regarding this issue? I hope you can give me a way to open my GPS.
Thank you.
Answered By 0 points N/A #154800
Hello Jem,
Here is the List of the Secret code for Samsung Wave on GPS
Reminder: Make a Backup files before going on and copy the codes. This will be formatting your phone entirely and will too reinstall the phone’s firmware. Consider prior to getting the codes. Though it only convey it back to its current firmware Bada 1.0.2 not the factory installed Bada 1.0.0
You should delete old GPS data to re-enable assisted GPS.
Codes are:  *#2663# Or *#2664#
TM Command
Secret GPS Menu: *#4097*4097#
Hope this works on you Samsung Wave.
