Bryan James
30 points
Posted on - 12/24/2012
I want a PHP script which is a real world application and shows how to use MySQL with PHP. I need a registered version software. Â
Can You please tell me where I script print pdf dengan PHP software? How much it will cost?Â
Where can I script print PDF dengan php software?
Hi Bryan James,
You can use the below tutorial for using MySQL with PHP. It covers all major topics included in PHP MySQL
A sample program can be foundÂ
here. It describes basic operations like Connecting to a database, querying of the database and printing the data retrieved.
Hope it helps.
Hi Bryan James,
Here is a solution to your query-
This PHP Generator for MySQL lets you generate high quality PHP scripts.
Key features include:
1. Data management: add, edit, delete and copy records
2. Customization of the HTML appearance
3. Filtering and sorting abilities
4. Data protection with a lot of security settings
5. Master-detail presentations
6. Event-driven content management
7. Data export to PDF, XML, CVS, Excel and Word
PHP Generator for MySQL produces clear and easy to understand code that can be used as is or modified in any way you need.
Run the online demo
Compare Freeware and Professional editions
Please use following link to know how to use MySQL with PHP-
http://www.freewebmasterhelp.com/tutorials/phpmysql
Thanks,
