Hello fellows,
Where can I search dell sound recorder? Is there a built in sound recorder in my dell laptop? I can’t seem to find one. But if there are some application or licensed software over the internet well it would be fine. I just need it for a business. I need your help.
Markus Raine.
Hi Markusa Raine, I searched solution that may help you with your problem.
Maybe you want to try this recorder called Sound recorder 1.0.
Very easy to use, can record upto 22 KHz. Even if the application is closed it still continues to record.
You can find and download it here:
http://mobile.afreecodec.com/sound-recorder-88307.html
Hope this information helps.
Hello Markusa Raine,Â
You can download dell sound recorder at this website: hptt://www.search. dell.com. You will find many types of such software. Go through them and see what suit you the best.
