Where can we get Android application for nonbrand tablet pc?
I bought two tablet pc (Teclast T720 WIFI V3.10) both of those has android 2.2 Os. I have tried to get the application for those Tablet pc from Android market. But android market does not allow to access those application for those non brand tablet pc so i will be glad to know the source from where i can download the application for my tablet pc.
Best Answer by tonymr
Answered By 0 points N/A #81035
To access android market you need to have Gmail account and via Gmail account you can sign into it. Then you can download available free software from android market. I do have android 2.1 smartphone (X10) i can download applications from the android market without any problem.
Still if you are unable to download applications from the android market just go to following link and download easy installer or any application installer setup file.
Or if you can surf the internet from your android tab just enable install application from unknown sources (you will find the settings on settings > applications) and go to below mentioned website (Download Link2) and browse software and install as you wish almost all the applications are taken from android market website. So you don't need to worry.
Answered By 0 points N/A #81036
Hello Sharon!
I will suggest you to download installer file in your tablet. Because installer does not check the tablet pc brands. So when you search any software in search engine add ".apk" in your search query.
e. g: If you want to download brizzle game. Search "brizzle game .apk" in Google.
