Barbera
30 points
Posted on - 08/02/2011
Hi All,
Where can we see which version/Firmware of apple has what fixes.?
Apple fixes lists/links/URL's
Each time when we connect the iPHONE to the laptop it checks for new releases and shows if available. Where can i check if the version has a fix you were waiting for.?
Can we read it some where?
Thank you
barbera
cgenius
Hi Barbera, believe me when I say this, alot of people have asked this question in the past, with the usual answer being no. Which is not 100% accurate there are a number of sites that you can get varying amount of information about changes from one firmware to the next however nothing in the form of an official change log from apple, I suppose there could be a number of reasons for this one of the main ones of course being security concerns, as it is with most software companies, they’d rather not tell you about bugs until long after they’ve fixed them, in any case depending on what information you're looking for you might be able to get some info from the following sites:
http://mac.softpedia.com/progChangelog/iPhone-Firmware-Changelog-38026.html
https://en.wikipedia.org/wiki/IOS_version_history
