Where do I download cute editor winforms to use in my development?
Hallo! I just started learning Microsoft ASP.net and would like to get cute editor winforms to use in the process. What are some of the options out there that I can use with ASP.net? Which one stands above the rest and which is free? If at all it has some price tag then it should be affordable.
Answered By 35 points N/A #171052
Hi there,
You can go for sharp develop, its free of cost. You can get it here- http://www.icsharpcode.net/Default.aspx
I feel freeware's have limited options, I would suggest you to check out DevExpress. It has some powerful features like winforms data grid, data editors, analytic tools and reporting tools. You can download the trial version for free here- https://www.devexpress.com/Products/NET/Controls/WinForms/
