Where do I download softphone for Windows auto record free?
I tried to find websites where I can download softphone for windows auto record free. But there were none where I can find it. Where do I download softphone for windows auto record free?
You are searching for the softphone for windows. You can download softphone for windows from the web i am giving below
www.3cx.com/VOIP/Softphone.html
Here you can download it for free.
You can also download it from other web sites. But here you can download without any charge. Please say thanks if i provided you the solution of your problem. Take care.
Hi Elyssaguadalupe,
You are looking for softphone for windows auto record
You can download softphone for windows auto record, Please follow these links:
http://www.voiceoperatorpanel.com/ (VOP Nano is a free, SIP softphone with Outlook and MSN integration)
http://www.fileguru.com/apps/auto_recording_softphone (There are many apps, you can download as per your requirement)
I wish this solution may be helpful. Thanks!
Best,              Â
Fenster Maxine
