Where do I find activation code dashboard in Socrates 3.0?
I have the latest version of dashboard which is 3.5.1.  I'm planning to build a blog site using Socrates 3.0.  I can't seem to find the activation code box in the dashboard.  I just had this problem when I updated to Socrates 3.0 from 2.0.  Where can I locate activation code dashboard?
Answered By 0 points N/A #165733
Hi Bilu Billa,
Dashboard has its own separate heading in the column on the left hand side of the screen, at the very top on the left. Please click on that and scroll down, I am sure you will find the location where you can easily activate the code 🙂
I guess it was a matter of not knowing where to find Dashboard rather than searching activation code box on the dashboard 🙂
Hope, this solves your problem. Please let me know if, in case it doesn’t.
