Where do I find and check Android battery charge cycle?
Hope to get an immediate response, how to check Android battery charge cycle? Where to find this with the Samsung Galaxy S III? Need to be familiar right away.
Hello Lance Sok,
Have you tried the Google Play store to search for an application that can do this job for you? Well I know of an application that analysis your phone, shows you which applications are using the battery and how much, battery time etc. I have given the download link below, try it out.
If you want to check your phoneâs battery level or the charge left on your battery, on your phone, swipe down from the top of your screen to open the Quick Settings. Here, you should see the remaining battery percentage on the battery icon. Now, to get more details about the battery level, tap on the battery icon. This should display two information about the battery:
To further expand the details, tap âMore settings.â This will show you a list of applications that have used the battery since the last full charge including how much battery every app used.
