Hi guys. I have recently upgraded my OS from Windows XP 64 bit to Windows 7 64 bit. My device manager is showing an exclamation point in the mass storage which means I have no driver installed for that hardware. Where do I get the mass storage driver Toshiba Pro? I have the Toshiba X205-SLi5 that has an Intel Core 2 Duo processor and 4 GB RAM.
Kindly use the intel site below
https://www.intel.com/content/www/us/en/support/topics/idsa-faq.html
Actually what it does is recognize a newer wireless driver or what some people may call it,the WIFI driver.But it wont detect the mass storage driver as you intended it to do. You can still opt to use the OEM version which is much reliable than the generic one.
You can also visit the Toshiba website and check if they have the drivers ready for purchase or download.
Good luck.
