Where do I get MX 900 editor software?
Hello.  I just purchased a used 418 MHz MX 900 Universal Remote Control for automating my PC and DVD Home Theater.  The problem is, no software came with it and I can't access the manufacturer's website.  Where do I get MX 900 Editor Software?
Best Answer by Randolph Brownlow
Answered By 0 points N/A #198401
The best place to get that software is from the manufacturer's website. If you were unable to access the site, you can try again later since the site might have been down due to technical problems. You can also try searching it from third party sites such as www.9down.com.
Fletcher Hoss
Answered By 5 points N/A #138839
Hello Dorin,
The only way you can obtain the MX900 Editor Software, is to access their website https://www.universalremote.com/ . In the upper-right corner, click on Contact Us. Fill out the form, and explain to them that you need the software.
After that, you will have to fax them a form, with your remote serial number and maybe other information. After that, they will provide you a link to download it.
I hope this information was useful for you.
Randolph
