Good Morning Friends,
I am looking for open source software for emailing newsletters to lots of recipients. I am using mailchimp but I am not happy with its limited features like it can store up to 2000 subscribers and send up to 12,000 emails per month. I need software newsletter open source which provides a better solution than mailchimp. Kindly tell me which one is the best to use.
Where do i get software newsletter open source?
I found a good application for you. It's called poMMo. You can download it and find more information at this link: http://pommo.org/Main_Page
This application will enable you to send massive amount of emails to thousands of recipients. This application is designed to be simple and straight forward so you'll have no problems using it. Since it's open source you can check the source code to be sure you won't be tricked or tracked. Feel free to check above link to get updated information.
