Where do I look for user account details?
Please give me an answer to the following question.
How can I find out if user accounts have local managerial access?
Where should I access this data?
Are the data even available?
Thanks in advance.
Best Answer by Lesten Pasio
Answered By 0 points N/A #102628
-To create a user account, follow these steps:
Click Create a new account in the list box Pick a task.
Type the name you want to give your account and click Next.
Select the desired account type, then click Create Account.
Answered By 40 points N/A #102629
Hi Pierce,
It seems you are needing information regarding user accounts in windows it seems. You can check that by going to start and then by clicking control panel and then search for user accounts in it (Windows XP and Windows 7 and or even Windows 8) and then click.
Control Panel Home User Accounts
Then you can access of all details of all your user accounts. There you can see on the left where you can access the data related stuffs, your credentials, linking online ID's, or even create a password recovery disk or manage your file encryption systems.
Hope that is clear for you and hope that solves your problem.
Answered By 0 points N/A #102630
Hi Lesten the great Lol,
Thanks a lot for the effort of posting all the screen shots.
Easy to follow to figure out the user accounts with local managerial access.
Thanks!
