Where do we find Specify Intranet Microsoft update service location
Generally Microsoft Intranet is a piece of software or a disk which is present in the PC which helps to connect to the internet and we can update the Intranet when we have a group policy.
Intranet update can be updated automatically with group policy.
If we have a group policy in our system before only then it is used to update but in the case it is not there. We need to create a group policy so that it could update the Intranet. To update and create the Group Policy follow these steps:
Go to Start
Enter RUN
In run type “gpedit.MSC”
Then there will be displayed a dialogue box of Group Policy object edition.
Click on either of the administrative template nodes.
Open the action menu.
Click on add/remove templates.
Add.
In Policy templates select wuan.adm
Open wuan.adm
Add/remove template
Close.
In above steps we have set up the group policy, now let’s see how to configure for auto updates:
Open computer configuration
Expand administrative templates
Now click on Windows updates.
Like this we can update our Microsoft intranet.
