Hi all
I need to find a cisco script editor for mac os x download as I can't seem to find after searching on the internet? Is there a specific website where I can download online for Mac? Or do I need to purchase from a store?
Where to download cisco script editor for Mac OS X
You can download Cisco Unity Express Script Editor from here but first you will need to create an account. After you downloaded the software, double click on exe Cisco Unity Express Script Editor file. The file will have a name as: CUEEditorx.x.x.exe. The three letters stands for the version release that you will install. Then, the InstallShield Wizard will begin to extract the necessary files for the installation. The wizard will guide you so, just follow the instructions. When the wizard asks you to choose between recommended or custom installation, choose recommended. You can cancel the installation at any time. Finally, check that the program works. The programs get installed in the following directory: C:Program FileswfavvidWFCCNEditor.exe.
I hope this is helpful.
Snapshot of Cisco Unity Express Editor. (1)Palette. (2)Design. (3)Debug. (4)Variable Pane.
There are so many CISCO editor for MAC. You can find number of video editor., pdf editor and so on for downloading purposes.You can use all of them or someone to insure that you can download in much easier manner. You can download Imtoo video downloader that is quite awesome. You can also download wondershare video download that is also quite awesome. You will also find AWCware that is also quite awesome. These are some of the most awesome cisco editor for downloading purposes.
Waters Magner
