Adams Baker
60 points
Posted on - 09/30/2012
I can't seem to find the right and working driver USB mobile Samsung Wave 723. I've check Samsung website but did not find it. The USB connection with my phone is not working properly. I read in one forum that I need to reinstall the driver.
Where to download driver USB Mobile Samsung Wave 723?
To fix this issue, go to http://www.samsung.com/ae/support/ and then scroll down and select the type of your Samsung phone. Choose Mobile Phone, select Smart Phone under the Subtype and then Select Samsung Wave under the Model Number. And then on the right side, download the Samsung Kies 2.0. Select for Windows if you are using Window-based PC or select for Mac OS if you are using Mac PC. Kies will help connect your mobile to your PC via Wi-fi and then sync contents.
