I need help with getting a driver for Toshiba Dual Band. My friend gave me their Toshiba Dual Band WLM-10U2 but they no longer have the CD and the box. I am trying to install this on my new Toshiba 406L758 LED TV and will be using a Linksys Router. Is there any website where I can download the driver for Toshiba Dual Band for free?
Where to download drivers for Toshiba Dual Band
Hi there Kenneth,
This network adaptor that you have from Toshiba is a plug and play device, meaning there's not driver included for it. To use the said device just follow the following instructions :
1.Turn on the power of the TV
2. Choose Preferences > Network Setup > Easy Setup > WPS Conguration
3. Select PBC > Push WPS button on your AP > wait until wireless conguration completed
4. Quit the setup menu > then launch internet application
Hope you'll be able to use your adaptor after this.
Waall Mike
