Where to download flash player 8 free iPad
Hello Techyv Friends,
Hello Rain,
Yes you can download and install the free flash player for your iPad. Many websites offer the download for the flash player, but it is essential for you to download it from a safe and trusted website. This minimizes the risk of getting a virus. Here are some suggestions for you. Please select any of the following links.
2. ITunes website (Recommended)
3. Download and installation guide available here. Please visit.
This will help you in finding a better flash player.
Hi Tait,
You seem uninformed about the restriction of Apple in using third-party software. In fact, you can not run Adobe Flash Player on your iPad as Apple does not allow other software companies to install any software that can alter the configuration of its system software. So you are quite out of luck there as you cannot install any Flash Player on your iPad.
However, if you are willing to run games and apps on your iPad, you can download them from the iTunes Store via the Internet directly to your iPad or to your iTunes in PC and then transfer them to your iPad via USB.
Regards.
Hello Rain Tait,
Congratulation for your new position. I appreciate your choice as I have also a fascination for iPad. Here is the link. Please visit and download for free flash player.
