Where to download Foxit PDF editor for Mac?
Do you know where I can find a Foxit PDF editor for MAC, the latest version and also including all the necessary add-ons?
Hi Olivia,
The Foxit PDF editor is an excellent software for creating engaging PDF files. In compared to its rival Adobe's Acrobat Pro, the Foxit PDF editor is simple, user friendly and less expensive.
As you wanted to have all the necessary Add-ons, you should download the Advanced Foxit PDF Editor and you can download it from:
https://www.foxitsoftware.com/downloads/
Hope this helps.
Hi Olivia Aust,
I am really sorry to inform you that Foxit Reader has not yet released their version for MAC OS. There are a lot of malware applications under the same name in the internet which claims to be "Foxit Reader for Mac" but the developers claim that they are just Trojans which will attack your MAC OS.
The only solution here is to use alternative software. If you are interested, please go through the below few alternative software for MAC OS.
Adobe Reader is one of the most widely used PDF reader and is easy to use:
https://helpx.adobe.com/reader/system-requirements.html
Chrome PDF Viewer Plug-in.
The new version of Google Chrome has incorporated a new feature of reading PDF uses a simple in built Add-on. It doesn't have much capability as Adobe reader but is faster and lighter.
https://www.google.com/intl/en/chrome/browser/
PDF Viewer (Firefox add-on)
This add-on enables to view PDF files in Firefox
https://addons.mozilla.org/en-US/firefox/addon/pdfjs/
If you are looking for PDF editors, then you can choose from the below list.
Preview.app – This enables to edit PDF files and is already included in Snow Leopard.
Adobe Acrobat Pro – It provides all features at a price of nearly 350$.
Skim – Light weight, customizable PDF editor.
https://skim-app.sourceforge.io/
Scribus – Open source PDF editor.
https://www.scribus.net/scribus-1-4-6-released/
Hope it helps.
