Where to download free games to pc from internet?
I was wondering if someone knows where to download free games to pc from internet? I have windows 7 installed. Any kind of help would be appreciated.
Hello Sharlene,
Some of the sites that I will recommend that you check out are the following:
Note that most of the games at the above sites are in the image format, and therefore when you download them, you still have to burn them on a disc for you to be able to install them. You may be lucky to find some which you just install directly to your computer. So you will need to have a burner like Ashampoo burning studio or Nero Express on your computer to be able to burn these games to a CD and then install them on your computer.
Carl
Just go to Google and type 'Best free games for Windows 7 download' and search, you will get a huge list. And download according to your choice.
Yet I'm giving you some links, you can try these below:
Play for free and enjoy.
Thanks for asking.
Hathy
