Where to download free PDF print tool to iPad?
I have iPad and want some free PDF print tool. Does anybody know where to download free PDF print tool to iPad? Any kind of help would be appreciated.
Hello Joey keen, Have a nice Day!
You are looking for some PDF print tool free for your iPad right. Ok, Don’t worry
Here I am going to suggest you some link from where you can free download PDF print tool for your iPad.
You can try the following link:
Download PDF printer free:
You can use the Joliprint Book mark in order to print PDF on iPad safari.
Put @my PDF in a message on twitter is another way of orienting PDF on iPad.
You also can use Air Print Activator on your iPhone,iPad or iPod touch.
Printopia is a great software
If you are looking for a PDF print tool for your Apple iPad, try To PDF. This iOS app is actually free if you simply want to convert pictures, contacts, and text messages into PDF format. If you require more than this like you need to use it for annotation or sharing PDFs, you need to purchase a separate copy. To PDF requires iOS 7.0 or higher and works on iPhone, iPad, and iPod touch.
The app was updated on iTunes on September 29, 2015 and is around 46 MB. The app requires a user to be at least 17 years old to download because of some mature themes. The app is fully compatible with iOS 9 devices. The latest version is To PDF 4.0. Another one you should try is the PrintDirect PDF App. You can use it to print your PDF file on your printer using your iPad.
Your printer should support network, Wi-Fi, USB, or Bluetooth connection to be able to use it on your iPad through a Mac PC or a Windows PC. The app can also be used on printers with Apple AirPrint support. PrintDirect requires iOS 5.1.1 or higher and works on iPad. The app was updated on iTunes on November 17, 2015 and is around 28.5 MB. The latest version is PrintDirect 2.1.1.
