Where to download a free version for asp.net objective questions?
I just want to ask if I can download this questionnaires and are there already answers for this questions that can be seen in the internet?
Hi Peter Gonzalez,
Hope you are doing good. Fortunately there are numerous links over the internet which provides objective tests for the ASP.net including there answers. A couple of them, which I recommend the most, are as following:
1. https://www.wiziq.com/tests/asp-net: You can go to this link and find plenty of free objectives of ASP.net and assess your knowledge of the subject. The good this is the tests are separated as per your expertise level. You can chose any of them and start you examination and can see your results as you login. Don’t worry login to this site is free and alternatively you can log in with your facebook account as well.
2. http://www.careerride.com/asp-net-multiple-choice-questions.aspx: This is also a very good test site for examining your asp.net knowledge base. The test is 1-page-1-question type and it also records that how long you took to complete a test. Moreover it also contains asp.net subject wise and expertise wise tests.
Hope you find this information helpful.
If you do a search on Google you will see many related links to your search query. Link below provides some questions and answers that can be asked in a interview. In interviews the most often they do not expect you to give a full oral answer but they expect you to have a good understanding and a basic knowledge about the subject. For interview purpose follow the questions in found in below link.
http://careerride.com/ASPNet-Questions.aspx
To get an understanding about usage and controls used in ASP.NET programming below questionnaires would be very handy.
