Where to download Linksys Key Finder Software?
I need the tool searching for Linksys Key Finder and I need the link through which I can search for the linksys key finder. Please let me know is it freeware or shareware tool? I don’t have any idea about it. I am waiting for the prompt reply from the users.
Best Answer by Kumay Edwards
Answered By 5 points N/A #159260
Dear Andrewjohn
You can find you Linksys key without using any software. Follow these steps.
  1. Start whichever web browser you use. You will not have internet access of course. But you just need to be connected to your Linksys only. Another way is to do this on the computer that is connected to the Linksys through cable. (requires no key, you will have internet access there)
  2. In the address bar, type: http://www.radmin.com/facebook/ipscanner.php
  3. You are now inside your Linksys router.
  4. Click on the “Security” tab on this page. You key will now be displayed to you. Write it down somewhere and try not to lose it.
  5. Use this key to connect to your Linksys WiFi
Hope this solves your problem.
Regards
Answered By 15 points N/A #159261
The Linksys key finder download is a freeware it can also be shared. If you want to download the Linksys key finder software check this link below:
1. Open your browser and copy this in your address bar http://www.fileguru.com/apps/free_linksys_key_finder_software
2. When you are already in the page, you can see in the upper left of the key finder “Screenshot” and download”
3. Click download
4. When the download is done install the program.
