Where to download original win vista sp3 iso
Where can i download an original win vista sp3 iso, so that i can re-install my Windows XP pro without having patches.
I would suggest you to check on Microsoft website here.
You will find support and download link to download windows vista service pack 3.
Alternatively, the best way to receive the latest Windows Vista Service Pack is to turn on automatic update feature. Click 'Start' button at bottom left of your screen, and type 'Windows Update > Change Update Settings to Automatic (Recommended).
Hi Roman Curtis,
To download an original version of Window Vista this link
It will lead you to a service pack center where you can get the latest for your Windows Vista.
A service pack is an update of the operating system that is normally a collection of previous releases.
They have several advantages
On your Windows Vista you can turn on Automatic updates if you are always connected to the internet. This way you will get regular updates. But if you are using limited internet you can be manually checking the internet for new releases on the link above.
They are free.
