The oxygen theme pack for Plasma workspaces have a photo realistic look and supports more icons, black theme etc. Oxygen theme pack is better in looking as well as performance. So I wish to download it for all Linux distributions. Where can I get it for free ?
Where to download oxygen theme pack for Plasma workspaces ?
Hello
I will guide you how to install oxygen theme.
Open terminal and enter following commands:
sudo apt-get install git build-essential cmake kdelibs5-dev kdebase-workspace-dev libxrender-dev libx11-dev
Keep you terminal opened and enter this command:
git clone git://anongit.kde.org/oxygen-transparent
Now go to directory where you downloaded your theme (in this example it's Home -> oxygen-transparent)
cd oxygen-transparent
Then run this script:
./oxygen-setup.pl
And finally run this command:
sudo make && make install
Now go to system settings and change your desktop theme, you can also customize it as you wish.
