caspian zec
30 points
Posted on - 12/05/2012
After taking pictures with my family on my new camera, I turned the camera off. When I turned the camera on, the pictures were unreadable. It seems these pictures are corrupted. I've tried to reset my camera several times. But to no avail. I believe it was an sd card problem. Is there any sd card tester windows compatible? Where could I download this freeware?
lee hung
75 points
Where to download sd card tester Windows compatible
Memory Cards might me unreadable because of internal damage caused by Shock Or Heat..
Your Memory Card Could be permanently Damaged but It Could Be Just a Glitch in the memory card file system.
To Find Out What Exactly is the problem You Can Use a Benchmark Software Like SiSoftware's Sandra from you can get it from http://www.sisoftware.net/
you can benchmark Read/Write Speeds of the SD Card and maybe compare them with a normal working card..
Please Note That This software does not perform any kind of repair to the memory card.
