I want to download tutorials for fat32 format. But I couldn't find such a website which gives an understandable video. Can anybody tell me , from where I can download tutorials for FAT32 format application?
From where to download tutorials for FAT32 format?
Hello Nel,
There are plenty of really useful click by click tutorials on the YouTube, so I would definitely recommend you to check there.
Also, instead of manually formatting your device, there are several software that can do that instead of you and save you some trouble (Team Xecuter for example).
Hello Nel,
FAT32 stands for File Allocation Table and it has to do with what format your flash drive has been formatted to use. Windows commonly uses NTFS or New Technology File System. It has nothing to do with the format your music files are in.
The PS3 is only able to read FAT32 formatted flash drives.
Following links will give you a complete understanding of the FAT32 format with video tutorials as well.
Thank you for your question. I think YouTube is the best way to learn anything rather than any other learning system. So, I suggest you to use YouTube for any learning solution please-
Though there are so many sites regarding this matter. But I think this may help you better than others
1....
