Where to download vb6 oci driver?
Where to download vb6 oci driver? Is there a freeware download for this kind of application? I want to know more about vb6 and to complete the installation I need vb6 oci driver. I hope you can help me guys.
Thank you.
Best Answer by Galaline Samuel
Answered By 0 points N/A #146905
VB 6 is no longer supported by Microsoft. Microsoft has removed support for the same. If you have any application that was developed in VB 6 and you want to run it in your environment then you need to think about something like run time installer. You can actually look into the site which is the below link which will tell you in more detail about how to use the same.
http://www.visual-basic-tutorials.com/
Please let me know if you need any more help on the same I will be glad to help you out with the same.
Samuel
