Where to Download Zen Cart Slideshow Templates
I am starting to build an e-commerce website using Zen Cart. I want my products to be presented in a neat slideshow. Where can I download or view Zen Cart slideshow templates?
You asked for the download and slideshow but let me inform you that Zen cart has added new features and plug-in which are might helpful for you to present your products on the website. To make them appear to marvelous look. Don't forget to install add-ons and plug-in.
Here is the URL to download Zen cart.
http://www.zen-cart.com/content.php?19-download
And here is the URL for slide show.
http://www.picaflor-azul.com/index.php?main_page=document_general_info&cPath=142&products_id=14824
Hello Carole,
First thing i would suggest you to build your e-commerce website using WordPress. It is much easier to develop a website and easy to handle. You can install slider plugin to show your slideshow but if you are comfortable with Zen cart then you should download Magic Slide Show for Zen Cart from here https://www.magictoolbox.com/magicslideshow/modules/zen-cart/ with this you can also set your slide show on your homepage as well as in any of your post. Instructions are available with the download link. Just follow them and you will have your slider on your website. For free Zen Cart templates here is a good website i found for myself : https://12leaves.com/zen-cart-templates-free/
Thanks
