Where Is ESXi 5.5 Web Client? I Cannot Find It.
I downloaded the free ESXi 5.5 web client. When I launch the app after installing it, it says all the new features are on the vSphere web client. I’m confused! Where is the web client?
It’s not a big problem that you are facing. Just a small confusion that you have. First, there is no web client for ESXi; the web client can only be used if you have a vCenter server. Now, if you only have ESXi host, and you still need access to the advanced features, you can purchase a VMware workstation license and manage your host from there. This will also allow you to use the advanced features. To learn how to use VMware workstation to access the features, follow the link.
I hope this cleared your confusion.
