I want to add Avast MSN plugin to my Mozilla Firefox browser, so whenever I receive E-mail to my MSN account, it may be scanned. Does anybody know where to get Avast MSN plugin? Any kind of help would be appreciated as I’m new to internet.
Where to find Avast MSN Plugin for Firefox?
Hi Elias cooper,
You do not have to install the Avast MSN plug- in.
Just make sure that you have installed the Avast and MSN plug- ins separately for your browser.
Also check the Avast web shield and protections options are enabled.
You will discover all the plug-ins for firefox at the underneath link.
http://www.backup4all.com/backup-plugins.html
Elias cooper,
To fix this problem you have not to install the plug-ins. You have to install this individually in both of them. And check the avast prtection shield is enable.
You can also use this link
Best regards,
Brandy Gilmore
