Hi to everyone,
Where to find backup logs on Samsung wave? Guide me on the step by step process for I am not yet familiar with Samsung wave mobile phone. It has a bada operating system and very cool structure. To all Samsung wave users please do help me.
Thank you.
Where to find backup logs on samsung wave?
Hello Friend,
I have a suggestion for you, as it can be applicable on “Android” and “Bada” OS too. It’s “Samsung Kies” software which is one of the best solution for your problem, as it has a capability for secure backup. You can easily backup your Mobile Phone’s data to computer plus you can restore your mobile’s data too. Download this useful software which is 100% according your need.
Hi Kathryn,
There is a capability of your Samsung Wave to restore your back up, I would think that the logs may be under the Samsung Wave folder on your program files. Since when you will try to restore your back up you need to plug it in the computer. Or you can try to look for it in the computer by files with an extension name of .SPB. This will then show you the list of all the back up files from Samsung that was made.
