Where to find book template indesign cs5
Asked By 15 points N/A Posted on -
Hi all,
I am a good writer. I write whatever I think. So decided that I will write some business making books. With which people can get profit. Where the whole ideas will be concentrated. But I think this can be made more easier if I use a template. By seareching internet I know that templates can be designed by using photoshop cs5. So please help me book template indesign cs5.
Answered By 80 points N/A #158670
Greetings James B Wiser,
Well you mentioned Photoshop and Indesign. But I think what you need is Indesign since Photoshop is for some different purposes. I found you some Book designs and you can check them here.
Just scroll down and you will see Book 1 then some text. Just Click on Book1 or Book2 or anything that you would like to see. You will download a zip file. Unpack it and open it in Indesign.
These are indesign cs4 templates but you can open them up in cs5 without any problems.
Depending on what you need you can also find some designs here.
Some require payment though, but if you find it useful why not.
I hope this helps you,
Regards.
