Hello experts,
Where to find the built in hp pink wallpaper? There are some samples wallpaper for windows 7 starter operating system with my hp laptop, but I cannot recall the location of the said wallpaper. Can you give me a step by step instruction to be followed? I need to set it as wallpaper.
Thank you.
Dear Kathryn Masud,
If you want a built-in HP pink wallpaper, you can find one at the following websites.
Thank you.
If you want to find the built in HP pink wallpaper then WinMatrix is a very good option for you. From that website you can find wallpaper and can keep wallpaper what you want. I think now your problems are solved and you will be happy after getting the wallpaper.
