Mia Molly
20 points
Posted on - 10/29/2012
Where to find the computer audio volume booster? I want to know the use and all the possible function and features of an audio volume booster. There are some from the internet but I don’t want to download some for security reasons. I want a licensed and secure software that will enhance my Acer laptop volume.
Mia Molly
Hi Mia Molly i searched possible solution that may help you solve your problem. If you want to boost the volume of your computer audio this may need programs from the internet.
You may download and install these programs that can be found in this link:
http://www.cccp-project.net/
It can double the volume of your computer audio. Or if you don’t want any programs from the internet better yet buy some better speakers. I recommend woofer 5.1 /7.1 or any cheap speakers but good quality.
Hi Mia,
               You can use the loudness equalization on your laptop no need for any add on software, here is how:
Do a right click on your speaker icon on your task bar, or access it from control panel and then sound
Choose Playback tab > speakers > properties
Choose enhancements
Put a check mark on Loudness Equalization and then click Apply.
This should make the volume on your computer much louder, however boosting the volume on a laptop can blow your speakers away and would cause garbled sounds. I would suggest getting an external speakers with amplifiers will improve the loudness of your laptop sound.
