Where to find correct drivers super box 4 Win 7
Where can I find all the correct drivers super box 4 win 7? Super Box 4 driver is not compatible with Windows 7. Can anybody help me?
Super box 4 is not supported by vista or windows 7. As many people have upgraded to vista and windows 7 there have been developments to provide the drivers for vista and windows 7. They are not yet available so you will not find any drivers to download.
Instead of drivers, you can download the patch file. The patch file makes it work on windows 7. You can get the patch file here http://www.onykage.com/blog/super-box-4-drivers/. See the screenshot below:
In the above screenshot you can see the iso file, just download the iso file and mount it on your computer.
