Where to find driver USB 2 dvr for laptop?
I had to reinstall my Windows and cannot remember wher I placed my drivers’ disk for dvr adaptor. I was wondering if someone knows where to get latest driver usb 2 dvr for laptop?
Best Answer by Carl Jack
Answered By 10 points N/A #133551
Hello Dixon,
Here is a procedure that will help you restore your USB 2 DVR driver for your laptop.
  • On your computer, you will need to go right computer on Computer, and the choose System Properties.
  • Check if the driver has been listed with a yellow icon and then right click on it.
  • After that click on Properties, and then click on the Details tab.
  • Next you will need to click on drop down menu.
  • The first one there should be the Hardware ID.
  • You will need to copy and then paste the hardware ID string and then you can look for a driver from here.
  • Another important thing to check the system specifications of your system and make sure that the driver you get matches those specifications.
Carl
Answered By 10 points N/A #133552
After the window installation you will be able to install the dvr for your laptop. First you need to install the window and after that you can get the latest dvr for your system. If you are searching for previous dvr version form your computer then use the search tool to see the related files by name.
Smith Thompson
