Where to find drivers USB super converter free download.
Help me to find drivers usb super converter, made in China. It would enable me to use my PS2 to connect to my PC. Being a Chinese made, I found it tough to search and find it in Chinese language enabled sites.
Answered By 0 points N/A #193787
Download your drivers for USB Converter for PS/PS2 joy pads Controller Adapter.
It may fix your problem and you can enjoy games. You must visit this site for more drivers related to your PLAYSTATION.https://www.hugedomains.com/domain_profile.cfm?d=electricquarter&e=com
I hope you would enable to use ps2 to connect to your pc. For installation, make sure that you plug the controller into the adapter.
During the running of computer plug the converter into the USB port. You just need to verify that the switch is set to either PS or controller.
During the emulation program it will help to hold the button before pressing accept.
