Trevor Jhon
40 points
Posted on - 10/12/2012
Hello Experts,
Where to find the flash projector with icon? I am using my hp Compaq Presario laptop and when connecting a projector on it how will I know if the flash projector with icon is located anywhere? Can you describe it to me? Your suggestions will be a great help.
Thank you.
Dear usually on laptops there is a function key from F1 to F12 used to display video on projector. This key is marked with an LCD type shape on the function key. So first locate it. This key will be used to shift display to projector. If there is not any shape or icon mentioned on the laptop then try function keys.
One of them will work for you.
Hi Trevor, The mentioned one is the best laptop for a projector. Firstly, you need to connect the projector to your hp Compaq Presario laptop. Then you need to go to the windows start button. From here you will find a SEARCH button. Type FLASH PROJECTOR ICON and press search, It will show you the flash projector icon. Thank You Jon,
