Where to find the grand theft auto 3 sound clips? I cannot find the data of the game’s sound clips, is it also possible to change or delete some of the built in sound clips? I am just wondering all the possibilities to make the game flow perfect and enjoyable. I need your advice about this issue.
You can check them out at the below embedded video playlist. The playlist is composed of the voices, music, and sound track used in the game. For your other question, you can’t change the built in sound clips of the game as they are installed and programmed in the game. Furthermore, editing the game’s built in sounds can result in game problems such as lags, system crash, or inability to launch the game.
Well your problem was where to find. So just do simple steps and follow one by one. I am confirmed that it’ll work for you so a really quick follow up to solve it.
You have to download these missing files from the link given below.
Copy all of these files to your main GTA3 directory. E.g., (/steam/steamapps/common/Grand theft auto 3/ audio/)
Now you have to cut the GTA3.exe and paste it in backup folder, now replace with it testapp.exe (rename it to gta3.exe)
Second thing you can change or delete the built in sound, it’s not impossible but the fact is if you want to do so then you have to manage all the files which would link with these built in sound files.
1....
