Emaily Rawa
10 points
Posted on - 11/23/2012
Hello friends,
Where to find the logmein scroll lock?
Tell me more about logmein settings and other important points to be considered in this logmein application.
I need to find some explanation on the advantages of using this kind of application.
Thanks and Regards,
Emaily Rawa.
Where to find the LogMeIn scroll lock?
Hi Emaily Rawa,
Please try this link maybe this could help you find LOGMEIN scroll lock.
LogMeIn is a remote access and a remote management. It can let you connect your host computer to another client PC.
You will be needing an internet connection to access it anytime, anywhere.
While Remote Management is a process of observing and checking on the configuration of multiple computers remotely.
One the advantages about it is that you can connect,configure and monitor another computer without be needing for you to go in there as long as you have internet connection then everything is good.
