Where to find Logos Foot help on iPad 2?
I've been searching all night but I can't seem to locate Logos Foot help on IPad 2. Any help will be greatly appreciated.
If you are looking for LOGOS FOOT a guessing game for football logo teams go to safari on your iPad 2, go to the small search bar on the upper right side then type logos foot help on Google search you will see first in the list is App Store Logos Foot tap on it and you will be redirected to IPad app store. then download the app.
This also applies to other apps if you want to search for them.
I hope this helps.
Thank you.
This is not so critical issue at all. You must go to the website to have this software download. Then you will be able to find your apps on iPad.
http://softwaretopic.informer.com/ipad-application-logos-foot-answers/
You would better go and justify that and make it easy.
