Hi guys,
Where to find the mobile huawei driver setup? I just got a new mobile phone huawei and don’t have any idea about the driver’s set up location. I just need some information from you, kindly guide me on to locate the settings.
Expecting some help, thank you.
Hello Christine Turner
I can give you an easy solution. Just follow the points below
1. Open your PC and go to the following link
    http://www.huaweidevice.com/worldwide/downloadCenter.do?method=index
2. Here you find a box to find your device
3. Find your device model here
4. 1st select the TYPE of product
5. 2nd select the device MODEL
6. When you select your device you will get a driver to download
7. Click on download and download the file.
Enjoy.
Thanks
Carrie Westmoreland
If you have a Huawei Smartphone and you want to install the driver on your computer so you can connect your phone to your computer, you just need to install the PC suite or the PC software for your phone. Since this is a Huawei Smartphone, just download Huawei HiSuite. This is the phone’s PC suite that you can install on your computer.
Installing this software on your computer will also install the phone’s driver which will allow your computer to identify your phone when you plug it on your computer. It supports Windows Vista, Windows 7, Windows 8.1, and Windows 10. It requires 1 GB RAM, 500 MB free space, and 1024 x 768 minimum screen resolution.
The Huawei HiSuite is available on Microsoft Windows and Macintosh. The Huawei HiSuite includes the following features:
- Application management – allows you to check, install, and uninstall apps on your phone fast and easy
- Screenshot
- Backup and recovery
- Message management – allow you to send and receive messages right within your computer
- Contacts management – allows you to delete, import, export, and manage contacts groups
- Video management
- Gallery management
- System recovery – allows you to factory reset your device
- Update – allows you to update and rollback your device
- Outlook synchronization
- File management – allows you to manage your files both in the internal storage and the memory card
The Mac version is limited only to the following features:
- Picture management
- Video management
- File management
- Backup/Restore
