Hi techyv,
Where to find the scroll touchpad for laptop driver?
I have to find the proper location of the touchpad drivers so that I can be able to check if there are some missing files in the installation.
The touchpad of my Acer laptop is not working anymore.
Just started to worry last week.
 Hoping for your help. Thanks.
Hi Â
Press Fn+F7 keys on your Acer Laptop. This is the key combination for enabling the touchpad. Â Fn key is located in left corner of the laptop keyboard and F7 key is located in the top of the laptop keyboardÂ
If does not work go to device manger and check if the touchpad appears there or there are any problems with drivers. And check your touchpad is enabled in device manager. If there is a problem you will see an exclamation mark with yellow colorÂ
Thanks & Regards Â
Mckinney Ma Â
