Angela King
10 points
Posted on - 12/21/2012
Hello techyv,
Where to find the setting for Sony Vaio remote control driver? The Sony Vaio laptop is the desirable device for those businessmen in the industry, it is user friendly and fun to work with but sometimes there are file locations and driver locations that is hard to locate. I need your help regarding Sony Vaio remote control driver.
Expecting some help from you guys. Thank you.
You can easily find the Sony Vaio remote control drivers. Unfortunately you didn't mention model of your Sony Vaio. Now the best option is to visit the Sony website, search your model and you will find all relevant drivers. For your convenience i am giving you a link which will help you to locate the drivers:
https://esupport.sony.com/US/p/select-system.pl?model_type_group_id=10
I hope it will help.
Dear Angela King,
You can find the remote control driver at the official Sony website.
Please go to the following URL which can help you in finding the required driver:
From there you can select the appropriate driver which you should download and then try to install.
Hope that this was helpful for you.
Best regard,
Don Muench
