Where to find specification of phone hardware? I got this new Samsung Galaxy S3 mobile phone device. I have all the details of its software capability and compatibility measurements as well. But, how would I know about the phone’s hardware? This is also important to avoid future hardware problems. Please let me know.
You can check for example a specialized website. You refer for example to this website. Or you can install some application to follow your hardware performance. CPU Spy allows you to see the lowest frequency used and especially the time in deep sleep (this application can be found on Google play).
For the battery, you can use BetterBatteryStats which only take screenshots: Partial wake locks since unplugged and kernel wake lock.
The Samsung Galaxy S3 is a 3G Smartphone operating on 2G and 3G network bands using GSM and HSPA technologies. It was announced to the public and released on May 2012 measuring 136.6 x 70.6 x 8.6 millimeters and weighing 133 grams. It uses micro-SIM card and has Super AMOLED capacitive touchscreen display with 16M colors at 720 x 1280 pixels screen resolution.
Samsung Galaxy S3
It supports multi-touch protected with Corning Gorilla Glass 2 featuring TouchWiz UI. It ships with either Android 4.0.4 Ice Cream Sandwich or Android 4.3 Jelly Bean powered by Exynos 4412 Quad chipset, 1.4 GHz Quad-Core Cortex-A9 processor, and Mali-400MP4 GPU. It supports microSD expandable up to 64 GB. It runs on 1 GB RAM with internal storage available in 16 GB, 32 GB, and 64 GB capacities.
The primary camera supports 8 megapixels with f/2.6 and 1/3″ sensor size featuring LED flash, autofocus, face and smile detection, geo-tagging, and touch focus. It supports 1080p video recording at 30 fps. The secondary camera supports 1.9 megapixels with f/2.6 and 720p video recording at 30 fps.
It has 3.5-millimeter jack featuring active noise cancellation with dedicated mic; Wi-Fi 802.11 a/b/g/n with dual-band, Wi-Fi Direct, DLNA, and hotspot support; Bluetooth 4.0 with A2DP, EDR, and aptX support; GPS with A-GPS and GLONASS support; NFC; stereo FM radio with RDS support; and microUSB 2.0 with MHL TV-out and USB Host support. It has built-in accelerometer, gyro, compass, barometer, and proximity sensors.
The pre-installed web browser supports HTML with Adobe Flash support. Java is not supported. It runs on removable Li-Ion 2100 mAh battery with standby time up to 590 hours on 2G and 790 hours on 3G. Talk time is up to 21 hours 40 minutes on 2G and 11 hours 40 minutes on 3G.
It is available in marble white, garnet red, pebble blue, titanium grey, sapphire black, amber brown, and la fleur colors.
1....
